I finished my first print and it came out like this
Print side
Print second side
Print top side
I calibrated all my axis steps and manual movement gives perfect numbers.
I am printing with these slicer settings:
Slicer settings
Slicer speed settings
I don't even know where is the problem to begin searching for a solution. It's my very first print after a couple fails and a lot of calibration to Z axis and bed leveling.
Update the printer without the heatbed as it's an older picture:
3D printer
The Z axis moves on 2 lead screws and 2 rods with bearings all of which attached to the plate.
  • $\begingroup$ please tell us the printer design or show a picture of it $\endgroup$ – Trish May 29 '19 at 5:53
  • $\begingroup$ It's a diy printer i am not near it rn to take a pic but i updated with a photo without the heatbed which is on the white plate basically $\endgroup$ – Eslam Karim May 29 '19 at 11:04
  • 4
    $\begingroup$ Your X belt needs more tension. Also you move a lot of weight (rods, aluminium plates, X stepper). The X belt does not power the carriage in the centre, you only have 2 bearings while you should use 3. All this adds to the (in)accuracy of the print. Also add a picture from the side please. It might be that the platform is too heavy that you are missing steps. $\endgroup$ – 0scar May 29 '19 at 11:30
  • $\begingroup$ i will add a side picture once i go to the printer. what do you mean x belt doesn't power the carriage and how can i minimize all those errors for example if i added 3 bearings instead of 2 would it matter? $\endgroup$ – Eslam Karim May 29 '19 at 23:37
  • $\begingroup$ Using 2 small bearings and attaching the belt closer to one bearing may cause the carriage to rotate and prevent smooth movement, a third bearing or a longer one prevents that. Please also explain by edit of your question in words how the platform moves; e.g. do you have 4 leadscrews raising the platform, how are they powered. $\endgroup$ – 0scar May 30 '19 at 7:22
I'd say that your axis aren't square, aren't tightened enough and you seem to have overextrusion as well. That would explain why all your layers are wobbly and not neatly stacked on top of each other, why your cube is far being being a cube (the picture of the X face shows it clearly) and the quality of surface finish on the top.
I do not know what kind of printer you are using, but I would advise you to check that the X and Y axis are correctly calibrated and that they're perfectly square, which would ensure that each layer is correctly stacked on top of the previous one to produce a nice cube. And make sure to tighten the axles to avoid the noise in the print due to the vibration produced by the printing.
As for the overextrusion, you'll need to make more test with your printer and the material you're using, changing temperature, and print speed until you find the right combination that will extrude just enough material through your nozzle.
  • $\begingroup$ Thank you i will make sure to check all of that about the extrusion how exactly do i set that is it in marlin or is it from pronterface because it's confusing me a little $\endgroup$ – Eslam Karim May 29 '19 at 11:08
  • $\begingroup$ I'm sorry but I cannot help further as I do not use marlin or pronterface with my printer, thus I'm not familiar with how they work. $\endgroup$ – Sava May 29 '19 at 14:07
    $\begingroup$ This looks like substantial amounts of overextrusion, I'd try fixing that problem before anything else. Change the steps/mm for the E axis in Marlin, there's extrusion tuning tutorials out there that can help you figure out how to get a good extrusion rate. Hint, you've got your steps/mm in the E axis set too high. $\endgroup$ – Nach0z May 30 '19 at 18:45
  • $\begingroup$ but when i searched regards the steps/mm every guide said cold extrude and measure the filament if it's the same number then the steps are fine and i am extruding exactly what i am giving the machine or is that can change sometimes? $\endgroup$ – Eslam Karim May 31 '19 at 3:05
