Does anyone have tips on improving build plate adhesion in DLP printers? I've heard a thin layer of resin or UV glue applied to the plate will help, but we're not sure if we leave the resin/glue wet, or cure it before we start the print. Apologies for the ignorance here, but I'm just trying to avoid gluing my build plate to the bottom of the resin vat! Any advice would be appreciated.
Update I had a product called ProtoGlass recommended to me in another forum, that apparently works as a good build plate primer for the resin we're trying to grow (BlueCast x5). Ordering today, and I'll update further with the results.
  • $\begingroup$ Welcome to 3dPrinting.SE! $\endgroup$ – Pᴀᴜʟsᴛᴇʀ2 Jun 22 '19 at 0:27
  • $\begingroup$ How about roughening the plate (with very fine grit) so as to produce more surface area "grab"? I do not know whether this leads to other problems. $\endgroup$ – Carl Witthoft Jun 24 '19 at 14:55
  • $\begingroup$ The plate on this machine (B9 Core) has a black coating (maybe anodizing, but not entirely sure). They warn against scratching the surface. $\endgroup$ – Stephen Jun 25 '19 at 15:13
-1
I have heard that adding a few pieces of masking tape to the print surface improves adhesion.
  • $\begingroup$ DLP printers are resin based. You can not add tape in that application. $\endgroup$ – Trish Apr 3 at 16:46
  • $\begingroup$ You can still use the masking tape though. I've done it on a DLP printer before. $\endgroup$ – ninja20 Apr 3 at 18:58
