I have an OpenSCAD model which I am looking at in the application, code to the left and the rendering to the right.
Am trying to modify a certain piece, and have commented out all the commands that I believed were related to that piece, but there is still one subtracted cube left, i.e. somewhere in the code there is a difference block with this cube command somewhere in the 2nd part (I believe, as I cannot see any other possibility).
It would be very nice if I could just click on the image and get the software to display the corresponding commands in the code.
Is anything like that available in any tool?
To my knowledge, OpenSCAD does not have any such feature. However, a related feature might help you: the debugging aid modifier characters. By inserting %, #, !, or * before an object (including aggregate objects), you can control how it renders in relation to the whole file; this makes it possible to do "binary search" type operations to figure out where the object you're seeing is.
  • $\begingroup$ I know. The problem is that I have apparently spread this out over the file, so would be tedious. $\endgroup$
    – Tomas By
    Jun 23, 2019 at 11:38
    $\begingroup$ It can be tedious, but those characters are the tools. I agree that a "point to it and the code opens" feature would be great, but as yet it does not exist. $\endgroup$
    – cmm
    Jun 27, 2019 at 17:47
