I burnt the Z- port for the Z endstop. Can I use the Z+ port? I'm using Jim Brown's Marlin firmware.
Any help to change that is highly appreciated. I know nothing about code. Sorry for my ignorance. I'm new on this 3D printing universe.
Sign up to join this communityI burnt the Z- port for the Z endstop. Can I use the Z+ port? I'm using Jim Brown's Marlin firmware.
Assuming line 585 of Configuration.h looks like this
// Almost all printers will be using one per axis. Probes will use one or more of the
// extra connectors. Leave undefined any used for non-endstop and non-probe purposes.
#define USE_XMIN_PLUG
#define USE_YMIN_PLUG
#define USE_ZMIN_PLUG
//#define USE_XMAX_PLUG
//#define USE_YMAX_PLUG
//#define USE_ZMAX_PLUG
That is to say, if the Maximum endstop ports/plugs aren't currently being used, then you could just redefine the pin used by ZMIN
(Z-) to be that currently being used by the ZMAX
(Z+), in the appropriate pins_XXXX.h
file (contained within MarlinTarantula/Marlin/src/pins/), where XXXX
depends upon which board you have (I don't know what board your printer has).
For example, if you have a RAMPS board then in pins_RAMPS.h at line 79 you would change
// Limit Switches
#define X_MIN_PIN 3
#ifndef X_MAX_PIN
#define X_MAX_PIN 2
#endif
#define Y_MIN_PIN 14
#define Y_MAX_PIN 15
#define Z_MIN_PIN 18
#define Z_MAX_PIN 19
to become (note the change in the last two lines)
// Limit Switches
#define X_MIN_PIN 3
#ifndef X_MAX_PIN
#define X_MAX_PIN 2
#endif
#define Z_MIN_PIN 19
#define Z_MAX_PIN 18
Then compile and reflash the firmware.
Obviously you would then plug the Z_MIN (Z-) wire from the endstop into the Z_MAX (Z+) port.
