-1
I am using Ultimaker Cura (4.1.0) as slicer and a Monoprice Maker Select 3D printer and have noticed that the reported print times when slicing are something like 25 % less than the actual time it takes to print.
Is there some practicality factor involved here? Have I failed to enter all relevant printer properties in Ultimaker Cura? Are these reported times not actually meant to correspond to reality?
Any insight is gratefully received.
Most likely Ultimaker Cura is not aware of the firmware's default limits on acceleration or jerk. Make sure they match either by increasing the printer's limits or decreasing the ones in the print profile to match.
