The printer is "Monoprice MP Select Mini 3D Printer V2".
This is how my printed fan part looks like:
Printed fan part
These printers are notorious for their Z lead screw assembly (M4 bolt & nut) so I installed flex coupler and aligned the M4 bolt and motor shaft so that the wobble is minimal. It is still there, but I don't think this amount of wobble would produce something like what I experience. Please check out the timelapse video at the end.
I also tightened up Z guide rails (no rattle, very little slop)
Moreover the banding appears to be less pronounced and have alot greater period for vase prints Vase print; extruded ellipse printed along Y axis
(this is extruded ellipse printed along Y axis). I tried:
  1. slowing down print by 50 % - no effect on banding.
  2. monitored hotend temperature with external probe on the heater block (-+5 °C)
The banding appears to be almost exclusively in Y axis direction; for example, the same ellipse printed along X axis: Vase print; extruded ellipse printed along X axis
Now, same ellipse in layered mode (seam side) printed along Y axis Layered print; extruded ellipse printed along Y axis
  • $\begingroup$ Please put photos in your question, not as links to external sites. $\endgroup$ – R.. GitHub STOP HELPING ICE Jul 2 '19 at 2:37
  • $\begingroup$ Do you know the lead screw's lead/pitch? What is your layer height? Made any calibration adjustments to steps-per-mm? $\endgroup$ – R.. GitHub STOP HELPING ICE Jul 2 '19 at 4:01
  • $\begingroup$ the lead screw is just M4 so i guess the pitch is 0.7 (according to metrication.com/engineering/threads.html ) and layer height is 0.3063. Didn't do any calibration adjustments. $\endgroup$ – Andrew Butenko Jul 2 '19 at 4:42
  • $\begingroup$ it would help if we would know the model - is it a perfect cylinder or can you show it? Also, this is a cantilever printer, make sure that the arm does not raise or lower during printing. $\endgroup$ – Trish Jul 3 '19 at 13:44
  • $\begingroup$ @0scar: How does 0.7×200 come up? If the pitch is 0.7 and there are 200 steps, it should be 0.7/200×200=0.7, not 0.7×200. But I'm skeptical that the pitch is actually 0.7. Does M4 mean actual M4 thread in this context, or just 4mm diameter with a metric thread profile shape but some larger pitch and possibly multiple starts? $\endgroup$ – R.. GitHub STOP HELPING ICE Jul 3 '19 at 18:23
This differs from the traditional banding as observed from Z wobble induced banding as e.g. explained in this answer.
Your banding patterns clearly seem to form diagonal bands, this is most probably a combination of the lead and the full rotation of the stepper. The most logical explanation is that the layer shifts as a whole in X-Y direction (when seen against the print height, this movement is concentric seen from the top). This means that the next layer is positioned over the previous layer in a concentric pattern. This hints to some sort of defect in your X/Y-plane assembly and should be investigated further.
This is difficult to visualize, but this sketch shows the issue for some layers:
Diagonal Z banding by concentric consecutive offsets
This could be related to the belts of the X and Y-axis, play on the drive pulleys, non-straight lead screw, guide rods with play, play in general, Z-stepper alignment to the threaded rod, etc. Considering the amount of Z-wobble fixes shared by the unofficial MP Select Wiki, the best place to look for is the Z-stepper to lead screw coupling.
  • $\begingroup$ It sounds like the lead screw might be bent (thus applying forces in the X and Y directions dependent on its rotational orientation) and like the Y axis belt may have more play/elasticity in it (or X if I read the description backwards). $\endgroup$ – R.. GitHub STOP HELPING ICE Jul 4 '19 at 3:55
    $\begingroup$ Thank you @0scar! I think your diagnosis is spot on. I checked slop and belts on Y axis before but didn't consider that bed heating cable might snag underneath the rails thus impeding proper Y positioning. I wouldn't expect this effect to have periodic rather than random effect though. but the issue is almost gone after repositioning of the cable. $\endgroup$ – Andrew Butenko Jul 4 '19 at 18:28
