I believe that CAELinux has successfully installed on a SD card on a laptop. When I rebooted what I am left with is a GRUB prompt. If I enter the chainloader command it expects things like the device name of the linux image. I really want to know if CAELinux has installed and if it runs OK. Then I shall learn more about GRUB because I have another distribution that I am interested in.
How can I simply start CAELinux from the GRUB prompt?
    $\begingroup$ How's this apply to 3D printing? $\endgroup$ – CrossRoads Jul 7 '19 at 17:48
  • $\begingroup$ CAELinux is a distrubution centered around 3D modelling and printing. I have tried posting on their forums with these questions regarding booting after installation with no reply. I know that it is off topic but this is the closest type of group I can find on the stackexchange to what I want to know. $\endgroup$ – Muscipula Jul 7 '19 at 18:10
  • $\begingroup$ Have you tried their forum (caelinux.com/CMS3/index.php/forum)? Seems a more appropriate place to ask. $\endgroup$ – 0scar Jul 7 '19 at 20:22
  • $\begingroup$ Yes I have and get no response $\endgroup$ – Muscipula Jul 7 '19 at 20:45
  • $\begingroup$ Go try the Unix and Linux, they may be better prepared to help on this matter. But I would imagine they suggest what I am going to suggest. Use a more common distro like Ubuntu and install the packages on that, you will find more support that way. Otherwise my guess is that the device of the sd-card reader does not match what grub is expecting and it can't find the kernel because of that. $\endgroup$ – r_ahlskog Jul 7 '19 at 20:58
Per the Getting Started page,
As CAELinux is a customized Xubuntu 16.04 distribution, the installation instructions (and then administration) for Xubuntu/Ubuntu all apply to CAELinux. For more instructions on how to install CAELinux on hard drive, please follow the Ubuntu instructions here: https://help.ubuntu.com/community/GraphicalInstall
Based on the information provided above, I think this question is off-topic for this site, and should be migrated to either Unix & Linux, or Ask Ubuntu.
  • $\begingroup$ OK it may be off topic, but I still think it is worth considering that this distro is designed for 3D modelling and printing. $\endgroup$ – Muscipula Jul 9 '19 at 6:35
