In Google Sketchup, I have text on a surface that I'd like to push / pull so that the text is etched into, rather than placed upon the surface. I can't seem to figure this out, the text disappears when I try to push it into the surface and I'm not quite sure what else to try. Any advice?
  • $\begingroup$ Have you tried ungrouping the text? It's created as a group, and groups will not intersect/merge with any geometry outside the group. $\endgroup$ – Ryan Carlyle Apr 27 '16 at 17:52
  • 4
    $\begingroup$ I'm voting to close this question as off-topic because it belongs in Graphic Design. The option is not available when specifying Off-Topic... $\endgroup$ – tbm0115 Apr 27 '16 at 20:55
Definitely you have to perform substract operation. Take a look here
Extrude text and then substract it from the object to etch in.
