This is a bit of a weird question, and I imagine the answer might simply be "no." But here goes anyway:
I'm writing some code that generates shapes for 3D printing via "implicit surfaces," i.e. a mathematical function f(x,y,z) that is positive inside the shape and negative outside it. This works pretty well for designing the kind of shapes I want to print, but the problem is, turning the implicit surface into a good mesh is hard - there are some libraries that can do it, but they're kind of finnicky and you have to play with parameters a lot to get it to work well.
But I was thinking: the only reason I need a mesh in the first place is to send it to a slicer, which will ultimately throw away the mesh and turn it into gcode instead. My plan was to do
implicit function --> STL file --> gcode
but I'm wondering if there are any slicers that will let me skip the intermediate step and let me just do
implicit function --> gcode
instead. That is, my code would supply a 3D grid of voxels, containing the value of the function at each 3D point, and the slicer would create the gcode from that instead of from an STL file.
It seems that Shapeways have a nice and simple format called SVX that is exactly this, but as far as I can tell, this is only supported by Shapeways and not by any FDM slicing software.
Another option would be for my code to supply a sequence of 2D polygons, one for each layer of the printed model, so the sequence would be
implicit function --> big list of slices --> gcode
This would be both easier and more accurate than first converting it into a mesh, and I assume the slicer must generate this kind of representation anyway, before it calculates the path for the print head to take.
I suppose the question is, is there an existing CAD format that supports either of these options, that is also supported by existing slicer software? If so then I can just write my code to output in that format and it should just work.
linear_extrude
and thentranslate
each slice to its appropriate height? Then render / export as usual. $\endgroup$
