Goal : create a pair of bevel gears for 90 degrees angle axles.
Context : the gears are designed with an OpenSCAD library (https://www.thingiverse.com/thing:1604369, function 'pfeilkegelradpaar'), then I try to modify them using TinkerCAD.
The problem : When printing the STL exported from OpenSCAD, everything seems fine. But when I import the STL in TinkerCAD, there is a separation where the angle changes, and I cannot seem to find a configuration that works.
Also, when previewing with Cura (tried with the older v14 as well as the latest v4), I get the same behavior : the exported STL creates a solid object, while the STL from TinkerCAD (even if not modified, just imported and exported) has a 'gap' of about 8 layers.
And, of course, everything fails afterwards.
Any help is appreciated. Thanks in advance.
