I have a weird problem, my object base starts good and then as the object goes to the next layers it is off centered. I have a picture to better explain.
4$\begingroup$ Layer shift is the keyword you should use to find existing info on this kind of problem. $\endgroup$ – R.. GitHub STOP HELPING ICE Aug 4 '19 at 22:25
1$\begingroup$ This is classic layer shift. There are lots of possible causes, but I would check for over-tight belts first. $\endgroup$ – Mick Aug 5 '19 at 3:55
Add a comment
