Running on the Marlin 1.1 firmware, for this issue, most other variables of the printer can just be assumed (It's a CoreXY design, but think i3 for my current testing). (Highlighted my only lead in bold, so probably best to read that first)
The problem: X-axis stepper driver and motor moves fine, all other axis's don't.
What I've tried and deduced.
- I've inverted all endstops and ruled out end stop errors, as well as any warnings that get reported through serial.
- Swapped stepper drivers from the Y axis (just focusing on the Y axis for now) to the X axis, the X axis is still the only one that moves.
- Swapped the X and Y axis motors: only the Y axis motor works, so still only getting powered from the X axis driver
- Tested power on the stepper drivers, all stepper drivers get the same motor and logic power within margin of error
- Tested step signal on the Y axis with an oscilloscope, found my only lead, when moving the X-axis, the step control has a peak voltage of ~5.2v and the motor moves. When testing the Y axis, the step input voltage from the Arduino to the driver has a peak of ~1.7v
- Assuming something may be wrong with the connection, I tested the resistance between all step pins from the Arduino side to the stepper driver itself and got a constant resistance of 2.5 ohms for all drivers, pins are connected properly.
- Pulled the Arduino out, uploaded and ran a custom servo script on it, using pin A6 as the PWM control signal. Server runs fine with the correct voltage (ruled out a microcontroller issue).
- Reassembled the RAMPS, motors etc, reuploaded a fresh copy of Marlin from their site that I configured from scratch and did some extra probing around to make sure all the connects are fine, still, only the X-axis works.
