Take the standard Hiwin rail, as commonly used in 3D printers:
They come in a max length of 2500 mm. Let's say I need twice that. If I connect two rails together end to end (as a "butt joint") and just bolt them into place, will it work as though it was one 5000 mm rail? Or are we limited to whatever lengths the manufacturers put out.
