I'm looking to 3D print a structure that won't deform in high heat, up to about 220 °C. The filament itself can be 3D printed all the way up to about 380 °C.
PEI seems like it could be a viable option. I found some here. This PEI filament specifies the glass transition temperature at 217 °C.
Would this filament work? Are there any other types of materials that would fulfill this engineering requirement?
3 Answers 3
Your expected operating temperature exceeds the glass transition temperature by 3 °C. This implies that the structure will become weak and can deform under load.
Note that you cannot simply print PEI on a normal machine, it requires a special high temperature capable printer with hot end temperatures up to 400 °C and heated bed over 120 °C up to 160 °C, furthermore it will need a heated chamber (up to about 80 °C) which requires special care to cooling and placement of electronics and motors.
Not having specified what kind of structure you require, you could look into steel.
PEEK is also used in applications where dimensional stability (and/or chemical resistance) over a wide range of temperatures is desired. The requirements for printing are similar to those for PEI.
An easier but less simple solution might be to make a PLA 'pattern' that is the right size and shape, then use that to cast your item in aluminium (melting point ~ 660C) using the 'investment' or 'lost PLA' process.
Links:- https://www.instructables.com/id/3D-Printed-Lost-PLA-Investment-Casting-Aluminium/
