Is there an efficient approach to discovering what is extraneous ("dead" or "unused") code in OpenSCAD to promote the learning process?
I am making progress by using working examples of code; however, some contain code with lots of modules and "test cases" (like gear generators) that aren't always used or referenced. These are great utilities but in trying to simplify the file to do only a small part of what is possible (usually by commenting out what I think are unused lines of code) things (to me) get very unpredictable. Reviewing the "AST Dump" has helped some but I'm hoping there is a more practical approach to isolating only the bare essential code.
  • $\begingroup$ This is a totally useless answer from a practical standpoint, but it is impossible to determine whether code is unused or not. $\endgroup$ Commented Aug 29, 2019 at 20:06
  • $\begingroup$ @TomvanderZanden: it is impossible only in theory (i.e. for all possible algorithms, or whatever). One approach might be to start from an empty file and copy the bits you want, and then add more in response to errors. $\endgroup$
    – Tomas By
    Commented Aug 29, 2019 at 20:39
  • $\begingroup$ Thanks, Tomas. With the more complex files I've encountered that have modules that references other modules and uses variable 'declared' in hidden parts of the lengthy code, it is more practical to start by commenting out suspected "extraneous" code. I was hoping there is a more efficient way of doing this - besides commenting out section by section to see what happens to the model. Though I can appreciate why it could be said to be impossible, I respectfully disagree entirely with that assessment. "Impractical"? Maybe, but that depends on each example. NOT impossible! $\endgroup$ Commented Aug 29, 2019 at 20:57
  • $\begingroup$ @TomvanderZanden: Rice's Theorem has nothing to do with whether code is used, just whether it's reached during execution. In most languages, for the program to be valid and identifier that's referenced must have a definition somewhere in the source regardless of whether it will be reached at runtime, so "used" is purely a static property amenable to trivial static analysis. $\endgroup$ Commented Aug 30, 2019 at 1:36
    $\begingroup$ @R.. The question asked about "extraneous (dead or unused)" code. I interpreted that more broadly, to include unreachable code (which is commonly called "dead code"). $\endgroup$ Commented Aug 30, 2019 at 5:49
I have written compilers and optimizers, as well as optimizers which work on raster operations. I so want to offer you a beautiful solution, but I don't know of one.
If I really wanted to solve this, I would start with this approach:
First, identify each token and expression in the OpenSCAD code. Assign each a unique identifier, and reserve one bit of storage, initially zeroed, that will be used later.
At the geometric database level, tag each geometric element with the identifier in the source code that generates it. Intersections become labeled with both operands and the intersection operator. Same with unions and other operations.
Then render the OpenSCAD form into some representation, perhaps voxels, perhaps STL. Voxels have a resolution limit but are intrinsically the simplest form. STLs might require an optimization pass to find redundant edges -- although that may already be part of STL generation process.
Now, go through the tagged representation voxel by voxel or triangle by triangle. Set the bit reserved with every token and expression to "one" for every identifier associated with that voxel or trianble.
Finally, check the bits on each of the source tokens and expressions. If the bit is zero, that particular element contributed nothing to the result. If the bit is one, that is needed in the result.
This is oversimplified because one source element can be used several times. Some may contribute to the output, and some may not. A fully expanded version of the source should be used, and we have to invent notation for reporting that instance 1 and 3 is used but 2 is not. I'm sure there are other over-simplifications which someone reading this will immediately realize.
I think, though, that this would be a path forward to the OpenSCAD optimizer you want.
In the meantime, OpenSCAD provides some prefix characters. One of the, maybe "*", removes a sub-tree from the generated geometry without messing up the parsing. I frequently use that mark to find out if code is used and to what it contributes.
