My Makerbot replicator 2 stops and restarts automatically. I lose the print and the extruder head does not move from the position. (obviously). We have checked wiring a few times. Have not seen any issues so far. Maybe I am missing something. We have recently changed the ceramic tapes, fans etc. just recently.
It happens once in a while. But once it starts, it continuous, and it doesnt stop unless we shut it down for a few hours. or sometimes even days.
Any ideas what the issue could be. Or are more details required.
    $\begingroup$ Have you tried replacing the X stepper and X endstop wiring? This is a common failure point due to wire fatigue, and if the +5v shorts to ground, it can pull down the mainboard voltage enough to shut down and reset the processor. $\endgroup$ May 5, 2016 at 16:07
  • $\begingroup$ @RyanCarlyle hey thanks. I think it could be the endstops wire. I removed the cables for both the motor and endstops, it ran for an hour. I attached the endstops, the printer stopped and restarted after a while. I can get the replacements from their website? $\endgroup$
    – albseb
    May 16, 2016 at 14:28
  • $\begingroup$ You can call Makerbot tech support on the phone and tell them you need to buy the X stepper cables. You can pay over the phone. They used to give a lot of them away for free since it's a known failure issue but I don't know if they're still doing that. Another option is Robotshop robotshop.com/en/makerbot-replicator-2-parts.html OR you can rig up something like an ethernet cable yourself. $\endgroup$ May 16, 2016 at 15:21
I've heard of a few issues like this, always relating to hardware problems. If you feel comfortable opening up the hardware on your machine, confirm that all of your connections are firmly connected to your printers Circuit Cards. The issues i've dealt with I determined came from a loose connection and the gantry running would shake the connections enough to cause a loss of signal.
  • $\begingroup$ So I replaced the xyz motor cables. It worked for a week or so. But I'm facing the same issues again now. $\endgroup$
    – albseb
    Jan 6, 2017 at 4:29
  • $\begingroup$ Check your power supply cables. If it's shorting out it could be causing a reboot. Make sure that there's no faulty connections on the XYZ motor cables you replaced and that they're fully plugged in (obvious I know) but doesn't hurt to check. Also make sure that the cable routing for the motors is installed the same way it was before you replaced them. Makerbot routed the cables in such a way to reduce the strain on the connector that's caused by the gantry vibration. If its an intermittent problem odds are it's either a vibration problem or a short circuit (or both). $\endgroup$
    – Diesel
    Jan 6, 2017 at 5:14
  • $\begingroup$ So we had loosened all the cables because of the terrible design. $\endgroup$
    – albseb
    Jan 12, 2017 at 14:35
  • $\begingroup$ I'll check power cables $\endgroup$
    – albseb
    Jan 12, 2017 at 14:36
