Recently my prints come out very messy. I tightened everything up and checked the extrusion multiplier.
I have an Ender 3 Pro which I use together with Cura 4.2.1 (and Octoprint). I print in PLA at 190°C. The print bed is set to 70°C. The Bed temperature is lower though, since I use a glas bed on top of the heated bed. I use a print cooling fan at 100%. The layer height is set to 0.2 mm, the line width 0.4mm from the 0.4mm nozzle. My retraction is 5mm at 45mm/s.
Does anyone have any idea what the reason could be?
