Can someone point me out an appropriate entry code for this task in Marlin source code?
Apparently, given one
  • has already enabled USE_<AXIS>_PLUG (for example <AXIS> = XMIN) in Marlin's Configuration.h,
  • one can add an additional define (for example <AXIS>_ENDSTOP_CUSTOM) in Configuration.h and
  • make this block the else statement in an <AXIS>_ENDSTOP_CUSTOM existence check, with the positive case being your arbitrary task.
The function that gets executed in the standard case in the linked block is PROCESS_ENDSTOP, so cloning it would be a good starting point to make a PROCESS_ENDSTOP_CUSTOM task, too.
| improve this answer | |
    $\begingroup$ Interesting - presumably you could then execute both the current endstop task (stop moving, indicate zero, etc) and some new tasks (launch cruise missiles, start playing Fast& Furious on the large-screen monitor). $\endgroup$ – Carl Witthoft Sep 24 '19 at 14:17
