Which of these will heat a bed fastest?
A. 12 V, 10 A power supply
B. 24 V, 5 A power supply
C. Both A and B will be the same (only total watts matter)
D. Depends on the situation
I originally thought Amperage was what mattered until I realized I needed a 24 V power supply to even heat my Lulzbot mini bed by one degree.
I know voltage is used to determine insulation thickness on wires. But thin wires with high current in them also get hot. Is insulation thickness on wires only to prevent you from accidentally cutting through them and shocking yourself, or is it for heat reasons?
I'd like to power my heated bed with a 19.5 V, 5 A power supply. It's just an old laptop charger - I want to reduce strain on my circuit. It's a big bed and I have a few other laptop chargers lying around so I'd prefer to choose the best one.
