I found this question, CR-10 randomly pauses for a few seconds, that someone asked earlier. I am experiencing the exact same thing, only on a CR-10S Pro.
None of the suggestions on that post helped. For what it's worth, I am using Ultimaker Cura 4.3.
Any help would be wonderful!
I made this video for someone I know from Creality. The pausing seems to happen at each new layer. But, as the layers pass like 4 layers then the pausing stops. This also happens on every print big or small. I changed nothing and it just started happening.
Quoting my comment from the previous question:
I am seemingly having the same issue only on Cura 4.3. There is no "Maximum Z Speed" anywhere on 4.3 so how can I fix this? As talked about above I just checked my "minimum layer time" and it is set to 10. I have also used another slicer and this same issue keeps happening it just messes up differently. I've also tried printing from SD card and OctoPrint. Same issue... How could this be my slicer if this same thing is happening on a different slicer than Cura?
minimum layer time
" may have an effect in this when the layers become small (in printed square mm). So, when does it pause exactly? $\endgroup$
