I was trying to print parts for a small CD-ROM drive based plotter based on this thing https://www.thingiverse.com/thing:3521286
But as tolerances are very small and need to match the existing parts, I realized that my printed parts are actually a little bigger, I made a test with a part like this:
_ _
\ .------------------------. ___
| [O]________________[O] | ^
| | |<--- 62mm ---->| | | |
| | | | 70mm
_| [O]________________[O] | _v_
\ _ / \ _ /
Side View:
[X] [X]
___[XXXXXXXXXXXXXXXXXXXXXXXX]____
A squared and mouse-eared frame with two protruding 4mm cubes on each corner with inner distances of 62mm and outer of 70mm between each adjacent cubes.
I discovered that, after measuring many times and averaging distances, my model printed 0.227..% larger.
I've heard of shrinkage factor for ABS or Nylon, and people compensate scaling their models while slicing.
But what about PLA?
Im using:
- Anet A8
- Stock marlin firmware (not the Anet one)
- Flashforge natural PLA 1.75mm
- 0.4mm Nozzle
- 0.2mm layer height
- 0.4mm line width
- 210ºC extrusion temp
- 60ºC Bed temp
- 40mm/s print speed
- Fusion 360, Cura 2.7 or 4.3 and Octoprint.
The printed model is pretty flat, has no curvatures or artifacts either.
Would this be an error of constants on my printer a known artifact from PLA?
