I have made some prints with the Ultimaker 2+ and Ultimaker 2 Extended+. The prints are in PLA. For slicing, I use Cura and I check the support checkbox (haven't gone to advanced settings to adjust support yet). I can clearly see that there is a little space between the support and the print. The supports often look like long pillars and such.
My question then is: "What is the best technique for removing the support?". Is it to use a knife, pliers or perhaps PLA-water? Is it possible to use PLA-water to remove support when printed with Ulitmaker 2+ or is that just the Ultimaker 3? What type of technique would give a good looking print?
Ultimaker 3 has support filament that's water-soluble. Is there something similar for Ultimaker 2+?
