Removeable beds are starting to get more common in low-price consumer-grade printers. There are pretty much 3 types:
  • Unheated beds
  • Heated beds from steel held by magnets or clips
  • Heated glass beds held by clips
Unheated beds are the lowest class, and not an issue here. What are the pros and cons for a steel/springsteel bed versus a glass bed?
In favor of glass:
  • Smoother surface gives you a nicer bottom layer (though Kapton-layered steel is no slouch)
  • More even, regular surface makes bed easier to level
  • Easy to prep and clean
  • More scratch-resistant makes getting under a part with a metal scraper a little less harrowing
  • Corrosion-resistant (glass doesn't rust; silicon dioxide is in fact already about as oxidized as it can possibly be)
In favor of steel:
  • Flexes for easier release
  • Safer (steel plates don't shatter, at least not at temperatures you're likely to use them)
  • Conducts heat better for faster and more even heating
  • Slightly less expensive on average
  • $\begingroup$ Surely slower conductivity means more even heating? That way the heat can dissipate more easily. $\endgroup$ Feb 21, 2020 at 16:32
  • $\begingroup$ "at least not at temperatures you're likely to use them" bwahahahaha $\endgroup$ Dec 14, 2021 at 17:23
