According to the instructions I have read, you use the same output on the printers mainboard to control a 110 V heated bed with a solid state relay, as you do to power the 12/24 V heated bed that comes with the printer.
The relay's datasheet states that its max input current is 25 mA, obviously a 12/24 V heated bed would draw a lot more than that.
How does Marlin know that the heated bed pins are controlling a relay now instead of a bed directly, and therefore should limit their current output?
In other words: I am worried that if I just drop in the relay, it will burn up since the board still thinks it needs to supply high current to the bed.
