So I just got the Ender 3 and have been trying to print out a part. However, I noticed the printer is trying to print the part, which should be centered in the bed, on the left side.
I performed the auto home, leveling procedures, prior to execution, but it still wants to print it on the left side.
I checked the values it thinks it has for X, but they are about 60 mm to high (i.e. from the control/move axis menu, I move it towards the zero position and when it touches the switch, it still thinks its around 65-70 mm in the positive direction).
I have tried the good old power cycle, but each time it seems to get worse printing closer and closer to the edge. I am sure that I must have fudged something up. Anyone know how to fix the mismatched position?
Thanks for any advice!
but it time it
you meanbut in time it
? Are you implying that there is layer shifting? I.e. the layer on top of the older layer does fit over it exactly, but prints shifted from the old layer? $\endgroup$ – 0scar♦ Nov 11 '19 at 11:54
