I've installed the an LV8729 on a kossel, configured with SKR 1.3 and marlin 2.0 with all the jumpers configured in the same way for 16 micro steps for X Y Z axis. Everthing seems fine the printer running well. I notice when I print, some tests prints, the dimension of a cube doesn't seems right, the on Z axis its perfect the the X Y I'm not getting the right dimension. Every driver have configured with the same vref value. Checking in the LCD configuration every driver axis had the same steps configured.
What can I do to despite the problem?
  • $\begingroup$ Hello mastervv! Your question is very terse and hard to answer without knowing a couple of things about your printer setup. Please edit and fill in the [placeholders] in the template I added and then remove the leading "<" and the trailing ">" afterwards. This will turn it visible and help us help you find the actual problem. $\endgroup$
    Nov 11 '19 at 13:20
  • $\begingroup$ How much difference in dimensions are you talking about? Please update the question, this is not enough information to work with! $\endgroup$
    Nov 11 '19 at 14:34
