In Fusion360, how do I align components according to their a midplane?
I have 2 complex objects. They have no midpoint defined (is that even possible). How do I align them according to their mid points?
There are several ways to lock items together.
Designed in position
When you design the parts from the base up, you should lock the very first sketch to the origin in some way or another. Fusion shows this by making any "well defined" line as black in contrast to blue, like shown here:
Left line: well defined
Using Components
Once you have bodies, you can pretty much move them around in the timeflow. You then can start to define them as components. Let's assume we have these parts, a bolt, and a part into which it hinges. Of course, these two are modeled "in place" but that hasn't to be:
Bolt and bar with hole
Now, we want to lock them together... well, first, let's start and put them into components! Highlight one, then choose the "new component" command, and make sure it stays highlighted, from bodies is chosen then hit enter.
New Component button
Repeat for the other part, so your tree should show 2 components now.
Components in the tree
Combine Components as modeled
Now we want to combine them as modeled, right? Ok, let's do that, it's easy! get out the dropdown from the combine menu and press combine as modeled (Ctrl + J)
Now, click both components and at first it will start to shake the screen, having chosen "Stiff" combination. This means the parts don't shift one against the other. If you had them in the right position in the first place, they will stay that way. But there are other ways, which are in the menu that popped up:
All possible combinations
If for example, I choose "rotation", I can choose a rotation center by placing a node as seen here:
Rotational constraint
Creating Joints between Components
Now, what if the components are not in position like the bolt is in the wrong position entirely? Well, start with components, as shown above, then we'll see:
Position
Now, we should use the joint function:
Joints
Choose the first Component, then seek the point which face-position (or for cylinders: position on centerline) shall be the first component's joint-point shall be. For our part, let's take the big part's hole. Click the face, then choose one of the available points. For cylinders that's the ends and the center, for faces, it's the corners, center points of the edges and the center. If you hit the possible alignment points in the first place, it skips the second click to choose it. Once that is done, the body turns transparent.
Select Face Select alignment point
Repeat the same process for part 2 and the magic starts: Both parts suddenly move till the alignment points are in the same position, the screen shakes and BAM! We are at stiff joint again! The menu changes and we can start to define offsets!
New options
