I've switched to industrial 3D printing. I use 3DSystems Flex 100 printer. As I print high detailed parts soon I've found out that I have to use quality control. Software is not a question. I use Geomagic Design X and Geomagic Control X. Sometimes I also Use Solidworks as I started my engineering way with Solidworks :-) The thing is that I have to choose a 3D scanner.
It has to work with small (3-7 cm in general) high detailed parts. I also would like to use the scanner as a helping tool with reverse engineering.
Actually, I have one scanner in my mind: 3D Systems recommended me the Artec Micro. I've researched all the data Artec provides... It sounds good, resolution, works with Geomagic software, bla bla bla... But when I've tried to search web for any user experience, I've found pretty nothing. I'm quite a noob with 3D scanning so I'm afraid to buy such a device without being able to see if it really suits my needs.
The question is: "Does anyone have experience with this or any other 3D scanner, used for similar purpose as mine an can recommend it, or tell me not to buy it?". Or any tips how to find out if the scanner suits my needs before actually buying it. I know how to choose the right printer, but scanners are confusing:-)
...can recommend it, or tell me not to buy it?
That is hinting to recommendation, not the experience. The community decides, but a rewrite of the question would be recommended to take away the "recommendation feeling". $\endgroup$ – 0scar♦ Nov 29 '19 at 12:39
