I just downloaded slic3r and setup my settings on it, but when I sliced and started the print, the head went off the bed and then tried to print. It doesn't matter what I set the origin to, it still does the same thing. Does someone more knowledgable with slic3r know how to fix this?
2$\begingroup$ did you define the offset of the home-switch position to the corner of the bed? $\endgroup$– TrishDec 12, 2019 at 18:21
$\begingroup$ Do you mean the origin? $\endgroup$– BluesandboxDec 12, 2019 at 22:53
2$\begingroup$ Please post screen shots of the build plate settings. Also state printer type or bed size. You can get some more information from this question. $\endgroup$– 0scar ♦Dec 13, 2019 at 8:54
$\begingroup$ Did you set slic3r with the correct print volume dimensions for your printer? $\endgroup$– Carl WitthoftDec 13, 2019 at 12:35
$\begingroup$ Yes I did, I also said it was the ender 3 (220 220 rectangle), and that it didnt matter the build plate settings, it always did the same thing no matter what settings it had $\endgroup$– BluesandboxDec 13, 2019 at 13:42
Add a comment
