I have a Flashforge Creator Dual.
One corner of my print bed is warped down. I am thinking about having a steel print bed made so it would tend to stay flat.
Has anyone tried this?
Sign up to join this communityI have a Flashforge Creator Dual.
Whether you should use steel or aluminum depends on the construction of your print bed stack. Either will work, but there are trade-offs involved.
Various considerations that may come into play:
So, it's really a holistic design decision. Aluminum is far more common because of its thermal properties and lower weight, but steel print beds (particularly with permanent adhesion coatings) are often used too.
I would consider getting another aluminum build plate for the following reasons:
In conclusion, I personally would not recommend using steel for your build plate as aluminum seems to have the most benefits. Yes, steel will be more rigid and durable, but I don't think that these should be variables that are significantly more beneficial over aluminum.
