Is the laser (or whatever light source it uses) visible? The cloudy film sounds like a good candidate for light diffusion and thus solidifying the entire resin, but if there are visible components to the light source it may help narrow it down.
If it uses a projector ("LCD") solutions, it may also be that the display that filters the light to certain regions of the resin to selectively solidify the print may be at fault, but that's rather unlikely.
The first thing that, in my opinion, you should do is to check that the object you are printing does not have a corrupt model file. Assuming that you have spare, fresh resin (if your resin is old, that's actually the most likely issue...) and it wasn't too hard to pry out that block, you could try printing something else that worked in the past.
While it's doing that, you may be able to see where/how it is printing. If the beam diffuses or lights up the whole area, you can tell if it's a printer issue (the film sounds like a good first thing to try replacing in that case). On the other hand, if the resin is old, it's probably just getting oversensitive and your printer is fine.
The resin is very touchy with these things, and has a shelf life of a few weeks to a few months, and less if it's ever opened.
