does anyone know something about Autodesk Ember print issues? Currently I am working on my master thesis and I would like to print with the Ember 3D printer a holder (see attachment) using the Luxaprint 3D mould from Detax.
This is the holder I would like to print with a size of 9 mm x 9 mm[1] enter image description here
My problem is as you can see it, the resolution of print quality is very bad. Does anyone has an idea how to solve this problem?
Thanks a lot!!
  • $\begingroup$ Hi Lisia, welcome to 3DPrinting.SE! It is a bit difficult to see with this low resolution image. Do you have some better pictures? $\endgroup$ – 0scar Jan 11 '20 at 15:10
  • $\begingroup$ Hi Oskar, Thank you! I add another picture maybe you can see the bad resolution of the print now better $\endgroup$ – Lisa Jan 11 '20 at 15:29
  • $\begingroup$ To be honest, not really... but in my defense, I'm nearsighted and colorblind. $\endgroup$ – 0scar Jan 11 '20 at 16:03
  • $\begingroup$ Okay, let me take new pictures and then I will upload it - sorry for that! $\endgroup$ – Lisa Jan 11 '20 at 18:02
  • $\begingroup$ what are the dimensions of the item? How long did you set the cure times? $\endgroup$ – Trish Jan 12 '20 at 22:17
