I am wondering if it is possible to print with a 3D printer from an SD card and connect to a serial host at the same time. I want to use the Marlin M118 serial print command to trigger custom functions running on a Raspberry Pi. The RPi would be connected to the printer over serial but would not be sending G-code. Is this possible?
My printer is the Monoprice Mini Delta. It runs a Marlin based firmware and I can install standard Marlin on it if necessary.
  • $\begingroup$ Welcome to 3DPrinting.SE! $\endgroup$ – 0scar Jan 15 '20 at 8:20
This can be done, but you need to have the right order of operations. Octoprint relies on such a setup.
  • Set up the serial connection first, as sending the connect signal from your terminal or Raspberry to Marlin triggers the printer to reboot.
  • After having the connection established, start the printjob either via the control buttons or the remote console (for example: Octoprint or Repetier Server, running on your Raspberry)
Note that you have to make sure not to dis- and reconnect the raspberry during print, as that might trigger a reboot of the printer!
