It's been about a month since I've started using my Anycubic i3 Mega and everything has been going great. But today, I left it alone to print a 3DBenchy and it suddenly stopped mid-print. I didn't see it stop but once I came to the printer, the motors and the bed were at ambient temperature suggesting that it has stopped for quite a while. I was surprised that the Bed Temperature registered at over 200 ºC (although it wasn't at all hot) and tried to stop the print. However. I wasn't able to stop the print (It said stop failed) and I couldn't change the temperature, so I just switched the PSU off.
After leaving it for a few minutes, I turned the printer back on and the Bed Temperature still registered at absurd temperatures although it wasn't hot at all as seen on the Image Below.
I then tested the Hot End as the temperature seemed normal and it does seem to work and I was able to get some filament to be extruded out normally.
Any ideas on what happened here? It was working fine for an entire month and was working fine for the day, but mid-print it just suddenly broke. I've also uploaded a GIF to Imgur to show how the bed temp fluctuates a lot. Any help would be appreciated :)
