I discovered "diamond" nozzles (name of the design, not the use of diamond material), which have multiple filament inputs (designs for 3 or 5) and a single output nozzle, see figure.
They look like a very good and compact solution to avoid or significantly reduce purge towers, where filament is wasted until the channel is primed, and to avoid a second hot end, which takes space and which could be oozing when unused, but I could find them only made of brass.
Are there hardened diamond nozzles, or equivalent systems which are lightweight and can avoid a second hot end, to print composite or abrasive materials?
