I have an Anet A6, an SN04 sensor for the Z-axis, and Marlin 1.1.x software that has automatic bed leveling enabled.
My question is (looking at the image below): "It seems my bed leveling is not working correctly. What can I do to improve it?"
You can see several things below:
- I tried to use glue to make the first layer adhere better.. works only for small prints;
- the middle part of the print is being done quite okay;
- the outer part are either too low or too high.
I used the following procedure to get my leveling "right":
First I set the z-offset with the M851
command, followed by M500
. Then I performed the bed leveling with G29 T
, followed by M500
. Then I started my print.
Maybe I need more grid points for my bed leveling, even though I have this interpolation method on. Or do I need to check the implementation of the bed leveling, maybe something is just plain wrong in the software.
What is your recommendation?
Current bed level status (M420 V
Send: M420 V Recv: Bilinear Leveling Grid: Recv: 0 1 2 3 4 5 Recv: 0 +0.709 +0.609 +0.519 +0.456 +0.448 +0.404 Recv: 1 +0.525 +0.440 +0.370 +0.325 +0.304 +0.298 Recv: 2 +0.368 +0.282 +0.222 +0.177 +0.189 +0.182 Recv: 3 +0.221 +0.152 +0.100 +0.055 +0.069 +0.082 Recv: 4 +0.086 +0.020 -0.028 -0.060 -0.050 -0.020 Recv: 5 -0.027 -0.093 -0.138 -0.187 -0.163 -0.146
