Configuration
- Printrun/Pronterface
- Slic3r 1.3.0
- Windows 10
- Arduino Mega + RAMPS 1.4
- Marlin 1.1.9
- Prusa i3 -- Hephestos BQ with following modifications:
- 450W PSU (230V to 12V)
- heatbed
- 3D touch
- led stripe
- ps_on with relay on the PSU
Issue conditions
I was printing fine until something happened, do not know what. What I can tell is I can reach any bed temperature with Pronterface, and for any duration. (my little 450 W PSU provides enough power for my needs, like 60, 70 or 80 °C, a bit hard for 85 °C though)
But as soon as start the print (when the temperature is already ready extruder and bed -- and as I always did), the motors move the extruder in the bed center and then I get the following error :
Error:Heating failed, system stopped! Heater_ID: 0
[ERROR] Error:Heating failed, system stopped! Heater_ID: 0
Error:Printer halted. kill() called!
[ERROR] Error:Printer halted. kill() called!
If I check the temperature with M105 ; temp report
, the printer gives me:
- before I press the "start print" button >>
T:245/245 , B:80/80
- after I press the "start print" button >>
T:245/245, B:80/0
so bed temp command is fine.....until I start the print
Temp command set to 0
What causes the printer to be halted is a huge temp difference between command and sensor. In the provided G-code, the bed temp was lowered to 30 °C, which helps :
- running the test faster
- this shows that the problem is still going on (bed temp command to 0 °C)
- I can "print" (move the nozzle without error but the PETG won't stick to the bed) and I don't get temp error.
See the full log here.
So, what does cause the bed temp command to get to 0?
Not from G-CODE
I checked in the G-code, and there is no M140 *0
nor M190 *0
until the end of the G-code, and I'm sure the problem is not comming from the slice/G-code because I ran some previously successfully run G-code/config and they fail the same.
Not COM related
I ran the same gcode on sd card (to see if the USB was involved), but the behavior is the same: as soon as the bed temp is reached and print started, the bed temp command is set to 0 (I can see command on LCD screen).
Hardware related?
I did not change the firmware, and print were going fine, before the printer was doing this, so I guess the root cause is Hardware.
Firmware involved
Because of the "0 °C command", the firmware react to something but I could not understand what is happening here.
when checking the firmware code, the only reasons why bed temp is set to 0 when print is running without asking for it would be
gcode_M140()
/gcode_M190()
: it could be bad interpretation of ascii command._lcd_preheat()
?PID_autotune()
: PID algo error?ABORT_ON_ENDSTOP_HIT_FEATURE_ENABLED
: maybe but it would also put the extruder temp command to 0
nothing that would really explain this...
Any hints?
