I have an Ender 3 with a removeable build surface. The build surface backing has become warped - the center is at least 0.3 mm higher than the corners. I'm not sure what the material of this plate is - it's the part behind the BuildTak-clone surface that sits on the aluminum heat bed and is clipped to it. This makes it impossible to level the entire bed, and annoyingly tedious to level it enough just to use the center, since the paper method doesn't work at the corners. Can this be fixed, or do I need to source a replacement for it?
  • $\begingroup$ uhm.. photo please? my Ender3 has nothing clipped. BuildTak is glued to the aluminium bed... Do you have the removeable build-surface? $\endgroup$
    Jan 28, 2020 at 21:27
  • $\begingroup$ @Trish: Yes, I think most of the later ones do; AIUI only early ones shipped with the buildtak-clone glued to the aluminum bed. Anyway the question was a setup for a self-answer because I figured this could be useful to others. $\endgroup$ Jan 28, 2020 at 21:32
  • $\begingroup$ Ah, that is the removeable Build Plate "upgrade", yes. I think that is a steel plate. $\endgroup$
    Jan 29, 2020 at 12:50
  • $\begingroup$ @Trish: It's definitely not steel. Reportedly it's some sort of acrylic. $\endgroup$ Jan 29, 2020 at 15:36
  • $\begingroup$ hmmm, could you share a picture of the backside of the plate? it could be some sort of fiberglass reinforced plate or something... $\endgroup$
    Jan 29, 2020 at 16:15
Yes. I rigged up the following setup with blue tape and clips and a pen for tensioning, used the nozzle (unheated) to hold the center down against the bed, and set the bed to 100 °C for about an hour. Afterwards the curvature was in the opposite direction and easily compensated by clips.
photo of the setup described above
If the backing of the build surface softens under heat, one might strap it into a contraption to heat, or just put it into an oven on a flat surface, baking it with some weight to flatten it fully.
An alternate to fixing the removeable build plate itself, one might considder to buy a (spring)steel plate and glue a new build surface onto it. Such a plate is really sturdy and would be mountable with the same clips. It might be also faster in heating behavior as steel is usually a better conductor than plastics. It might be thinner than the original sttack though.
Now such a steel plate also is magnetic and could be alternatively mounted by adding a set of high temperature resistant magnets set into the heat bed. Such a rework does however have a higher work needed than a pure fix.
