I've built a a PrintrBot inspired printer with a moving printbed for the X-Axis movement. It's controlled by a RAMPS board running Marlin firmware. And there is a problem with the X-Axis positioning.
As can be seen in the image the X-Axis is not really stable. The blocks should be 10x10x10 mm, and the top and bottom are perfect. The waving does not appear in the Y-direction, it's only in the direction of the bed movement.
Each block was printed at different speed, from medium to dead-slow. I limited the acceleration and in the last block I also limited the non-printing speed so the bed would never experience a higher acceleration than with the printing itself. But the wave effect remains. And it's also remarkably repeatable so it looks more like a synchronisation error somewhere. Does anyone has a clue, or experienced a similar effect ?
