I have an Ender 5 printer, which is a frame-based printer with no enclosure. However, I want to print ABS. Some experiments with a massive cardboard box have shown me I need an enclosure.
Because the printer has a box frame, fitting some perspex sheets will be easy. The bit that won't be easy is the top - the filament tube projects fairly high.
Will I need to cover the top for ABS though? I read somewhere that drafts are a killer for ABS, which perspex around the sides should prevent. I guess most of the heat from the heat bed will be lost out of the top, so will this be a problem for layer adhesion?
  • $\begingroup$ I'm going to do the same and would suggest checking this link out for adding a top to Ender 5 It has a top and mitigates the X/Y movement issues. $\endgroup$
    – JCJ
    Mar 11, 2020 at 12:10
  • $\begingroup$ Interesting, thanks for the link. I'm using a spare cupboard I've found. $\endgroup$ Mar 11, 2020 at 12:22
3 Answers 3
Sides without a top will help.
Sides with a top will help more.
Do you need either? That depends. How warm, how dry, how drafty is your printing room?
  • $\begingroup$ The room is not particularly warm, but it isn't damp or drafty either. It's a box room. $\endgroup$ Feb 8, 2020 at 4:56
From experience I can tell you that boxing it up completely is not always a good thing to do. I have covered the front and top of an Ultimaker 3E printer to find out after some printing time that the cold ends weren't getting enough cooling, so I ended up clogging the nozzle assembly, preventing finishing the print. If you need to box it up to create a higher enclosure temperature, you better be sure the electronics, steppers and nozzles (that are in the enclosure) are cooled properly or do not get too hot, or alternatively you need to regulate the enclosure temperature.
    $\begingroup$ Okay that's interesting. I think I'll try boxing the sides first and see what that does. It is quite a cold room (not centrally heated so about 14-16 °C this time of year), but I can try setting the build plate to 100 °C. $\endgroup$ Feb 8, 2020 at 5:00
If ambient temp gets under 70°F, layer adhesion becomes a real problem. I have found that enclosing the space and adding heat makes the printing more reliable.
This answer is based on a few years of solely printing ABS. I've got my printer on a tool cart and the spool holder is above on a post. The first time winter ruined a print, I threw a pallet covering plastic bag over all of it and put a small, low powered, forced air heater more or less pointing at the printing area. It wasn't air tight, but I made effort to close it up pretty well.
The current location of the 3D printer is on the bottom tier of the cart with a temperature controlled heater pointing at it. I opened up a large amazon box and set it against the cart, forming walls on 3 sides. There is poor sealing but the print quality stayed good.
Oh and obviously it is very dangerous and have burned down my workplace and home several times, so don't do it.
    $\begingroup$ I can't tell if you're saying that an enclosure is needed or not. Please clarify. And welcome. $\endgroup$
    – Davo
    Feb 12, 2020 at 14:12
  • $\begingroup$ If ambient temp gets under 70°F, layer adhesion becomes a real problem. I have found that enclosing the space and adding heat makes the printing more reliable. $\endgroup$
    – Krista K
    Feb 12, 2020 at 19:43
    $\begingroup$ You might want to edit that into your answer, as an opening summary. $\endgroup$
    – Davo
    Feb 12, 2020 at 19:56
  • $\begingroup$ What is your last sentence saying? I can't tell if you are being sarcastic $\endgroup$ Feb 19, 2020 at 14:55
    $\begingroup$ @marcellothearcane 3D printing communities across the internet are very much safety police now. I guess there is not any more common sense. Yes, much sarcasm. $\endgroup$
    – Krista K
    Feb 20, 2020 at 20:09
