BuildTak is great because the printed plastic really sticks to it, it pretty much solved all the problems I had with prints detaching from the buildplate during printing.
However, it does sometimes cause the opposite problem of prints sticking too much and just not detaching from the build plate.
I'm specifically not asking how to prevent this from happening - I'm asking what to do after I made a mistake and now have a print that isn't coming loose.
3 Answers 3
I would do as fred_dot_u initially suggested, by increasing the bed temp (or using a hair dryer) to heat the BuildTak. Then, use a small fan to quickly cool the platform (or at least quicker than room temperature). An ice pack on the build plate/part could also work. This drastic fluctuation between the build platform (or BuildTak) and the part should make it easier to remove the part.
This works because the temperature coefficient is going to be different between the build plate, BuildTak, and the 3D printed part. So, each part rises and falls in temperature at different rates. When objects are heated and cooled, they expand and contract (respectively). Essentially, as each object expands and contracts at different rates, the objects begin to separate.
A good example is if you've ever placed a jar into the fridge/freezer to make it easier to open. Typically the jar is glass and the lid is either plastic or metal. You'll notice that the lid is significantly easier to open, as opposed to its original state, because the lid and the jar physically react differently to temperature changes.
Also, here is a good article explaining a few different ways to remove a stuck part. (for prosperity sake, here's a quick list):
  • Brute force. Just try to yank on it until it pries off.
  • Sharp objects. Try using a small blade to get under a corner of the part and wiggle the part a bit. Careful not to break the blade and send it flying.
  • Utilize temperature difference. I already explained this above.
  • Use solvents. I didn't know this, but apparently there are solvents in the market that are targeted for 3D printing maintenance. Essentially its just an alcohol-based liquid...
  • Use floss. Another cool idea that's related to using a sharp object, using dental floss. Basically, any small object that you can remotely wiggle under the part and give you more leverage to yank on it.
  • Invest in a flexible build platform. I've personally heard some mixed reviews on these (in present day of 2016). But material science is getting better every year, so who knows what will be available soon.
  • $\begingroup$ With using sharp objects, a wood chisel works well. $\endgroup$ May 22, 2016 at 19:05
If you have a heated bed, bring the bed up to a reasonable temperature, then do as best as you can to create rapid cooling. If you can remove the bed, heated or not, consider to place it in a freezer or refrigerator. Obviously, if the bed is heated, you'll want to handle the bed carefully and not place it on anything in the freezer that could be damaged while it cools.
Unrealistically, pour liquid nitrogen over the bed. This may crack the bed and/or the model, as well as be all the more dangerous for unprotected users.
Use dental floss. It sounds a bit crazy, but I tried it for the first time yesterday, and it works like a charm.
  1. Wrap the floss around two handles for comfort.
  2. Loop the floss over the print. All the way down against the build plate.
  3. Start pulling towards yourself, slowly but firmly.
  4. Work the floss side to side if necessary.
Once the floss makes it all the way to the front side of the print, it will be removed from the buildtak cleanly, without torqueing the bed unnecessary, or popping the print of suddenly and flinging it across the room.
Glide style floss works better than waxed.
  • $\begingroup$ Interesting idea, but requires a lip. Most of the time when my prints are stuck there is no easy to access lip. $\endgroup$
    – StarWind0
    Nov 6, 2018 at 18:46
    $\begingroup$ Give it a shot, the last model I printed didn't have any lip to speak of and the floss still worked. Floss is intended to get between things, a little bit of back and forth should do the trick. $\endgroup$
    – linuxdan
    Nov 7, 2018 at 3:01
