I want to put a spiral lid on top of a container. When the lid opens, then the spiral mechanism will rotate into the container. Is there a name for this mechanism? If not, would something like this be possible?
$\begingroup$ Please post a drawing of what you are thinking of. If Iris diaphragm or "venus box" suffices, that's great, but if you'd like something more complicated we need to see it. $\endgroup$– Carl WitthoftFeb 27, 2020 at 16:55
It sounds like you're talking about an iris diaphragm. This has many parts that slide against each other, and would best be printed as separate parts, then assembled.
$\begingroup$ Thingiverse also has examples of both the iris mechanism and the venus box. $\endgroup$ Feb 27, 2020 at 16:18
No spiral lids that I know of. I'm not sure how they would work, anyway. There are plenty of designs with hemispherical lids -- so-called "Venus" boxes. Check Yeggi:
