I have a Monoprice Maker Select V2 (Wanhao Duplicator i3) on which I've installed a recent version of Marlin.
The home position is at the front-left of the build plate. At the end of the print, the print head returns to this position by moving the build plate back.
Can I modify this to return the print head to the back-left corner, so that the print ends with the part more easily accessible?
Here is the default G-code for this printer in Ultimaker Cura:
M104 S0 ;extruder heater off
G91 ;relative positioning
G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+0.5 E-5 X-20 Y-20 F{speed_travel} ;move Z up a bit and retract filament even more
G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
M84 ;steppers off
G90 ;absolute positioning
