I'm running the autotune PID because I had to replace the hotend. The command that I launch is M303 E0 S200 C9. But from the temperature chart I see that he has only made two cycles, after which the autotune control seems to have gone mad and has remained stable on 213° C and is no longer doing autotune cycles. After a while I get Recv: PID Autotune failed! timeout.
I am using Marlin Firmware version 2.0.3 (GitHub) installed on a MKS Gen v1.4 (Arduino MEGA 2560) board. The MKS Gen board replaces the original one of a Geeetech Prusa i3 Pro B. Hotend is 12V.
Do you have any suggestions? Has anyone experienced something like this?
UPDATE:
I redo the PID Autotune and now I get a sawtooth:
  • $\begingroup$ sawtooth is good, it is rather close, though... not close enough. maybe tune with ess than 9 cycles? 3 to 5? $\endgroup$ – Trish Mar 10 '20 at 17:09
  • $\begingroup$ I am giving a try using 3 cycles. $\endgroup$ – kitsune Mar 10 '20 at 17:25
