I have a LultzBot TAZ 6 3D printer and the software I use for my prints is "Cura LulzBot Edition - 3.6.3". Recently, I have begun to play around with the parameters in Cura relating to initial layer adhesion. One such parameter is the Initial Layer Flow Rate
Now, after manipulating this parameter several times and evaluating the pieces that have been printed subsequently, it seems quite apparent to me that a manipulation in this parameter is affecting all subsequent layers that are printed.
For example, if I increase the Initial Layer Flow Rate
from the default setting of 100 % to 130 %, layer 2, layer 3,...layer n all appear to be printed at at a flow rate of 130 % resulting in prints that are clearly "overextruded" (e.g. the finished surfaces are incredibly uneven, bumpy, etc).
Similarly, if I decrease the Initial Layer Flow Rate
from the default setting 100 % to 70 %...all subsequent layers are clearly underextruded (e.g. walls are not connected at all and floor/ceiling have visible gaps).
Why is this happening? Directly above the Initial Layer Flow Rate parameter is a parent setting that is simply named "Flow". (refer to below picture)
Do I need to manipulate flow in order to avoid this from happening?
All I want to do is change exclusively the initial layer's flow rate (for better adhesion on larger pieces)...but my current method is not accomplishing this. Any suggestions?
$\color{red}{\text{EDIT}}$ - After reading the comments, I just wanted to clarify that I have let my parts "be printed to completion". The obersvations that I am making about underextrusion or overextrusion are in reference to the total structure (not just the first several layers). These are large structures (~12 hour prints).
G1 Xn Yn En.nnn
(extrude n mm) commands. Cura marks each layer in the G-Code with "Layer: n". You could have a look, if the extrusion length differs for the same line in layer 1 and 2-n $\endgroup$ – Michel Feldheim Mar 11 '20 at 16:36
