I have some issue with my BLTouch (I'm new to bed levelling) : I compiled Marlin 2.x (for my SKR 1.3) for a Antclabs BLTouch, and everytime I power on the printer, it shows this error message: Failed to enable Bed Leveling, echo Bed Levelling off, echo : Fade Height 0, FF, ok:
BLTouch error message on LCD display
The LED of the BLTouch is on, I can still deploy and stow the pin, and do "levelling ABL" but Homing Z (for example) is not working. I linked the config.h and config_adv.h in case needed below:
  • $\begingroup$ I have potentially find the problem, need time to confirm, and I'll write here, but thanks $\endgroup$
    – math45
    Mar 11, 2020 at 2:03
  • $\begingroup$ it's fixed : it's because I didn't level the bed once after flashing the firmware, once it has been done the error is no more $\endgroup$
    – math45
    Mar 11, 2020 at 3:12
From a comment can be read that the OP found the solution:
  • $\begingroup$ How did you level the bed? Each time I press home, my print head goes all the way to the end rail and try to keep going until I turn off the power. $\endgroup$ Apr 29, 2021 at 2:37
  • $\begingroup$ @MarcusMiles Please post your own question, it will attract attention and possibly answers, it will not receive answers here in comments. Please take the tour and read help center how SE sites work, we're not regular discussion forums, instead it's a simple Q and A format. $\endgroup$
    Apr 29, 2021 at 21:24
