I'm using a 200x200 mm PCB Mk2B which connects to the MOSFET of the D8 pin on a RAMPS 1.4 shield. I used 12 V power source for heat bed so I connected positive to pin 1 and negative to both pin 2 & 3 of the bed. Heat bed worked properly. But the wires that connects power source to power supply pin on RAMPS were being heated badly. I think the problem is come from heat bed because when I unplugged heat bed, wires were cool down instantly.
Can someone helps me with this problem. I'm just a newbie in this area.
