I have an Ender 3 and I have a problem with auto home. I use auto home and then level the bed with the wheels beneath the bed. I then start a print and the first layer is well above the bed. Perhaps about a millimeter. If I stop the print at this point and level the bed so that the first layer prints the normal paper width above the bed, everything works fine.
The stops for the 3 axes seem to be in the right places and there is nothing noticeable obstructing them. When I use auto home it does touch the stops at all 3 axes. My belts seem to be tight and there is no movement of the bed if I try to jiggle it with my hand.
Is there a way to adjust the Z axis so that the auto home elevation and the elevation of first layer of the print will be the same?
This is an example of the first lines of G-code:
;FLAVOR:Marlin
;TIME:4724
;Filament used: 1.70716m
;Layer height: 0.16
;MINX:96.551
;MINY:96.545
;MINZ:0.2
;MAXX:138.448
;MAXY:138.455
;MAXZ:100.4
;Generated with Cura_SteamEngine 4.5.0
M140 S50
M105
M190 S50
M104 S200
M105
M109 S200
M82 ;absolute extrusion mode
; Ender 3 Custom Start G-code
G92 E0 ; Reset Extruder
G28 ; Home all axes
G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
  • $\begingroup$ Does this answer your question? Recalibrating Home-position $\endgroup$
    Mar 18 '20 at 18:36
  • $\begingroup$ Welcome to the Stack Exchange. You need to define an offset of the home from the endstops. Here are one two three questions about the same thing! $\endgroup$
    Mar 18 '20 at 18:38
  • $\begingroup$ To me, this sounds more like an incorrect start G-code script. Maybe you can post the G-code? Also, please explain if this is a vanilla firmware, or have you flashed a new firmware version onto the board? $\endgroup$
    Mar 18 '20 at 22:03
  • $\begingroup$ I was having the problem with the original firmware so I flashed a new version (Ender 3 Firmware_1.1.6) and get the same problem. I don't see any way to attach a file. I doubt that it is an error in the G-code because I've updated Cura and it still does it. I'm using Cure 4.5.0. I've also had this issue with Thingiverse files $\endgroup$
    – Daknife
    Mar 19 '20 at 0:38
    $\begingroup$ I kind of have an idea why it might be: there are variants with a glass bed out there, you might have grabbed one of those! $\endgroup$
    Mar 19 '20 at 10:01
The Z stop can be loosened and moved up but it seems weird that it would need to be moved and I don't think that would fix your issue. The Z height should be the same for the auto home and printing. I auto home then disable steppers and slowly move to all 4 corners. I have caught myself resting my arm on the X axis and moving it down. If that happens I manually move the Z until it just barely presses the Z stop in when I hear the button click. I have heard some say that they got a warped bed. I wonder if that's the issue. A glass plate would be a good way to be sure or maybe using a straight edge to check.You could also double check the tightness on the wheels is just right. Tomb of 3D Printed Horrors has a really good setup video called "Creality Ender 3 assembly and pro build tips" that has a few other tips that really helped me get set up well.
  • $\begingroup$ I don't think its a warped bed because once I get it going I dont have any issues with the bed. The Z-offset is currently set at +.2. I can't get it to move to negative numbers. Is this normal? $\endgroup$
    – Daknife
    Mar 19 '20 at 1:48
  • $\begingroup$ @Daknife What do you mean with a 0.2 mm Z-offset, maybe you should explain this in the question as if you use the endstop for levelling, an offset other than a piece of paper during levelling would not be necessary. It's unimaginable that the Z axis homes lower than the bed requiring you to insert a positive Z-offset. $\endgroup$
    Mar 19 '20 at 6:38
  • $\begingroup$ I guess I used the wrong term. I was refering to the value under Prepare>Move Axis>Move Z $\endgroup$
    – Daknife
    Mar 19 '20 at 15:20
From the added G-code instructions you can see that the printer is instructed to go down to a height of 0.3 mm (G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position). If the printer nozzle is not at 0.3 mm height, there must be a Z-offset present in the firmware or incorrect placement of the endstop.
