I am very frustrated with some weird solid infill issue, mostly due to sloped wall such as chamfer for fillet.
Here is an example. I have a 20x20x20 mm cube with 2 mm rounded chamfer at the bottom shown in the figure.
When I slice it using default 0.20 mm profile, at layer 5 I can see some wiggle solid infill near the wall, shown in figure:
I thought that is to help create the chamfer. BUT, if I increase the bottom solid layer number to 50, at layer 51 (which is way above the chamfer region already), I start to see that same wiggle solid infill again! This can't be correct... Shown in the figure:
I am using the most recent PrusaSlicer 2.2.0
The reason I want to get rid of those wiggles is because they create crazy vibrations which then create layer shift for me...
Any help will be appreciated!
  • $\begingroup$ What software did you create the cube in? Also, please post the setting for slicing (most relevant); it appears that there is a solid infill layer at layer 50? Looks as if 2 cubes are stacked... $\endgroup$
    Apr 8, 2020 at 6:01
  • $\begingroup$ Stiffen your frame. That should be your foremost concern. Just throwing that in here. $\endgroup$
    – user77232
    Apr 8, 2020 at 13:39
  • $\begingroup$ user77232, the wiggles of note are not structurally related, they are coded into the build by the slicer. $\endgroup$
    – fred_dot_u
    Apr 8, 2020 at 15:28
  • $\begingroup$ What are your wall settings -- thickness, etc. $\endgroup$ Apr 8, 2020 at 15:57
  • $\begingroup$ Please answer in which software the cube is designed. $\endgroup$
    Apr 8, 2020 at 21:59
