I have 2 STL files that I want to chop, rotate, and glue together. If I printed them and literally chopped and glued them together, I would be done. Very simple operations.
I imported them both into OpenSCAD, but I can't find docs or figure out a way to do anything to the STL files once they are imported. They imported fine. I don't know how to assign a variable name to the imported object, which I presume is the next step before I can rotate and move the objects around. I might be going in the wrong direction though, I don't know. usually during an import of a module you can assign a variable name, or instantiate it. Since the import also instantiates it, I'm at a loss for what to do next. I've programmed in a smattering of languages, but haven't touched OpenSCAD in ~3+ years.
When searching, I find a cornucopia of slightly related information like how to import a file from 2011, but nothing about how to work with it once it's been imported.
One can create a module to import the respective STL files.
module bring_it_on_1() {
import("c:/user/models/egg_on_face.stl");
translate([-10, 20, 0])
bring_it_on_1();
Other modifiers can be used and will act on the STL file appropriately.
